Question "DRIVER POWER STATE FAILURE" BSOD with Asus Z590 Tuf Gaming Plus WiFi ?
Oct 15, 2021
I built new PC (Asus z590 tuf gaming plus wifi + i5 11600K + 32 GB CRUCIAL Ballistix RAM)
The system crashes every few hours with bsod (DRIVER POWER STATE FAILURE)
Attached mini dump files
https://1drv.ms/u/s!AhsddJcTWUdSd9g-Cnd57pcgd3c?e=zK7z0b
And screenshot https://yadi.sk/i/_Y3CSw1rMMveIA
  • Tried two power supplies Gigabyte 750H and Chieftronic powerplay gpu-550fc.
  • Also tried inserting / removing the video card ASUS radeon r7 360. And enable/disable IGPU hd 750.
But the error keeps popping up ?
Hi, I also have z590-f rog, also have driver power state failure.
Hoping I've sorted it, I can't read logs but here's what info I've gained from the interwebs.
It's usually a driver error or a device sleeping that won't wake.
I hope someone more knowledgeable can help you, but thought I'd share what little I know.
I'd try updating bios, checking display , sound, WiFi drivers.
Also check your power plan, I've set everything there to best performance vs energy saving.
Hi again, I'm gaining with mine, hoping it's fixed.
I'd try this.
Download WinDbg .
Let it analyse your dump.
Mine listed the issue HDAudBus.
Apparently it's not always so simple.
Doesn't always list issue and needs more work
Worth a shot though.
I also found this link, worth running after bsod imo, can't hurt.
https://support.microsoft.com/en-us...em-files-79aa86cb-ca52-166a-92a3-966e85d4094e
