Driver Update Problem! HELP!
Binohill14
6
First off I have a Radeon HD 6670 Graphics Card. I've recently been playing black ops 2 and always got stuck on awaiting textures. I was told I need to update my drivers but there's a problem, I have no Catalyst Control Center! When I try to install it, the program never shows up. It says it successfully installed but it when I search for it in my computer the install file comes up. I've went into Windows Device Manager and it says my drivers are up to date, but when I go to AMD"s website i see a newer version. I try to download it but of course, I have no Catalyst Control Center. I have no idea how to fix this, and I hate getting into a match a minute late when playing bo2. Please any help would be appreciated, Thank you
go to "run" from the menu and type msconfig.exe and press return
than go to the services tab of the system configuration window and check if the ccc app is enabled and running.
sort out the manufacturer and check if all apps from amd are running and if not enable it.
do the same with the start up tab too.
also you can go the program files on your system drive and start the program from there.
