[SOLVED] DRIVER_POWER_STATE_FAILURE (9f)
SpicyCatGames
4
EDIT: not really solved. Intel ethernet driver bricked my PC. Removing in safe mode didn't help, found out there were no restore points. Ended up resetting windows. If you stumbled here looking for a solution, you won't find it here.
Windows 10 crashes randomly. Got this from a dump file but I have no idea what I'm looking at.
Here is the .dmp file
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffffc20f429d1360, Physical Device Object of the stack
Arg3: ffff8c888404f150, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffffc20f495c8520, The blocked IRP
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 3109
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 33022
Key : Analysis.Init.CPU.mSec
Value: 1843
Key : Analysis.Init.Elapsed.mSec
Value: 85196
Key : Analysis.Memory.CommitPeak.Mb
Value: 85
FILE_IN_CAB: 091622-8859-01.dmp
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffc20f429d1360
BUGCHECK_P3: ffff8c888404f150
BUGCHECK_P4: ffffc20f495c8520
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
MODULE_NAME: pci
FAULTING_MODULE: fffff80252a00000 pci
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffff8c888404f118 fffff80250b60047 : 000000000000009f 0000000000000003 ffffc20f429d1360 ffff8c888404f150 : nt!KeBugCheckEx
ffff8c888404f120 fffff80250b5ff61 : ffffc20f49fc51e8 0000000000000000 0000000000000000 0000000000a8475d : nt!PopIrpWatchdogBugcheck+0xdf
ffff8c888404f190 fffff8025089da12 : ffffc20f49fc5220 ffffd201e5300180 ffff8c888404f418 0000000000000000 : nt!PopIrpWatchdog+0x31
ffff8c888404f1e0 fffff8025086766d : 0000000000000000 fffff802508e91e5 0000000000140001 0000000000a8475d : nt!KiProcessExpiredTimerList+0x172
ffff8c888404f2d0 fffff802509fc45e : 0000000000000000 ffffd201e5300180 ffffd201e530b140 ffffc20f42faf600 : nt!KiRetireDpcList+0x5dd
ffff8c888404f560 0000000000000000 : ffff8c8884050000 ffff8c8884049000 0000000000000000 0000000000000000 : nt!KiIdleLoop+0x9e
IMAGE_VERSION: 10.0.19041.1741
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x9F_3_POWER_DOWN_e1d68x64_IMAGE_pci.sys
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {b79a619a-9aad-eaab-8ed9-84180b8fe5ac}
Followup: MachineOwner
Conversion of dumps
report - Click run as fiddle to see report
File: 091622-8859-01.dmp (Sep 15 2022 - 22:07:12)
BugCheck: [DRIVER_POWER_STATE_FAILURE (9F)]
Probably caused by: pci.sys (Process: System)
Uptime: 3 Day(s), 8 Hour(s), 18 Min(s), and 20 Sec(s)
What Make/model Notebook? this one? DCL DCJ503 - Interesting time finding their website. I think its this one https://daffodil-bd.com/ but i don't see your notebook there.
not sure what this is
Jan 25 2021ANXUcmCxCD.sys
Its made by Analogix semiconductor but I can't find much more
Oct 29 2019InputDirectorVirtualDriver.sys
Software KVM to control multiple computers...
Conversion of dumps
curious software
Since most of your drivers are Intel, I would run this and see if it offers anything new - https://www.intel.com.au/content/www/au/en/support/intel-driver-support-assistant.html
Conversion of dumps ...
Hey, thanks a ton. I did a bit of research and tried analyzing the dump file. Found this resource Bug Check 0x9F DRIVER_POWER_STATE_FAILURE - Windows drivers | Microsoft Learn and tried the !irp command. I don't understand much but the word "e1dexpress" comes up which I had also seen on event viewer around the time of the BSOD
I also see this during startup
The driver \Driver\WudfRd failed to load for the device PCI\VEN_8086&DEV_9A03&SUBSYS_9A038086&REV_02\3&11583659&0&20.
This hardware id also seems to be related to ethernet. The drivers I can find for my LAN card or whatever doesn't seem to have the same versions available at the same date as the one installed (both from Intel). I'll install the official drivers from Intel's website and see if that fixes things.
@Colif About my laptop, it's given from my university for free, they own this computer brand. But no manufacturer website with drivers sadly. They also use a lot of unknown brand Chinese parts. I don't wanna get rid of this now tho because computer prices are super high in this part of the world.
Oh also InputDirector is just another tool for sharing keyboard and mouse over LAN. But it seemed to have less lag than MouseWithoutBorders. I keep the process turned off most of the time so I doubt that's it.
