I have just completed an editing/streaming workstation using the following components:
This suggest that I could hook the output of the 3060 to the input of the TB port and use USB-C to drive the monitor. The monitor would simultaneously act as a USB hub providing 2 USB 3.2 gen 1 ports on the monitor. This would allow me to use those inputs for the microphone and the webcam greatly simplifying my cable management at this station.
Am I delusional? Is it the case that I could drive the 3400 x 1440 monitor and collect the outputs of the microphone and camera using a single cable? This would also free up two USB 3.2 gen 1 inputs at the back of the machine. I actually have a second camera that need a place to hook up.
I did notice that the Ace manual states that it supports TB-4(40Gbit), USB 3.2 gen 2x2(20Gbit), USB 3.2 gen 2(10Gbit). It does not say it supports USB 3.2 gen 1. Surely it could not be true that this mode is not supported? Also the manual for the LG states that it supports USB 2.0 with one connector and USB 3.2 gen 1 with another. Could it be the case that I am that close but no cigar because the Ace does not support gen1 on the TB-4 port?
I am not a gamer. I will do 4k video editing and streaming of PowerPoint presentations using OBS. 60Hz refresh is sufficient for my needs. If this is too much to ask I would like to be disappointed now rather than after I get this monitor. I would still likely purchase this monitor as most others are aimed at gamers.
FYI: My current monitor is a 12 years old Dell that runs at 1080p60. There is no problem with it other than no DP inputs and it will not talk to my BMPCC 4k using HDMI.
- Intel 11900k
- MSI Z590 Ace
- RTX 3060
- Logitech BRIO webcam
- Elgato Wave 3 microphone
