[SOLVED] DSL Info
Kilichenko
Hello,
Can you please tell me that my dsl info is good or not?
DSL synchronization status:
Up
Connection status:
Showtime
Upstream line rate (kbit/s):
3072
Downstream line rate (kbit/s):
30719
Maximum upstream rate (kbit/s):
33215
Maximum downstream rate (kbit/s):
90120
Upstream noise safety coefficient (dB):
31.7
Downstream noise safety coefficient (dB):
15.9
Upstream interleave depth:
Downstream interleave depth:
Line standard:
VDSL
Upstream line attenuation (dB):
15.6
Downstream line attenuation (dB):
12
Upstream output power (dBm):
5.5
Downstream output power (dBm):
14.5
Channel type:
Fast
DSL up time:0 days 3 hours 5 minutes 28 seconds
because adsl+internet lights goes off (unstable)
Can you tell me if there's any problem with my dsl info please? and what about noise coefficient (known as snr margin)?
when to consider its bad or good even line attenuation?
Thank you.
That looks OK.
Signal attenuation between 5 and 30 dB is ideal fro reliable connection...higher values lower the line quality and consequently lower the data transfer (speed)
How is the quality of the cables?
