Hi. I recently purchased a Corsair h100i v2 240mm AIO cooler. I noticed that there is a gap between the fans and the radiator due to the screws being too long. That also causes audible vibration on the case. My idea was to install two 120mm fan gaskets under the fans.
My question is, is it better to get two 120mm gaskets or a single 240 radiator gasket, and if the part of the gasket(the 120 one) that touches the radiator could maybe melt and damage the radiator?
Thank you.
Thank you.
