Question Dual D5 watercooling build question
Kcimor
79
Hello.
Im thinking about puttong together a system with 4x 360mm radiators, one gpu and one cpu. The rad space might be overkill but ill be able to set the fan speed very low. I also want low noise from the pump, so, i want to use 2x D5 pumps working together on a dual D5 pump top, the alphacool eisdecke. I want the dual pump top so i can run the pumps at low rpm and still have enough pressure.
I have a thermaltake pr22-D5 pump.
My question is, can i use the thermaltake pump with any other D5 pump, like vpp655, for example, or will i have to buy two pumps that are the same model??
Thanks
