Dual monitor help
zeosinclair
13
I'm currently looking to get a second monitor so I can have a dual monitor setup. Just wanted to double check if what I'm planning is doable.
This is the graphics card I have, http://www.amazon.co.uk/Gigabyte-Nvidia-GTX670-PCI-E-Graphics/dp/B009KFT04S/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=3U418Q9N6AEPW&coliid=I3EMXDNXVAW808
This is my current monitor, http://www.amazon.co.uk/LG-Electronics-IPS224V-PN-Flatron-IPS224V/dp/B0081Y2IHU/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=EPHO2SFSUJI4&coliid=I8N49CCVADPTG
This is the monitor I'm looking at, http://www.amazon.co.uk/LG-22EA53VQ-21-5-inch-IPS-Monitor/dp/B00BWOJ35G/ref=dp_ob_title_ce#productDetails
What I'm planning is to use the DVI ports to make a dual monitor setup, or if the DVI's are the same on both monitors and I can't find an adapter I'll use one of the DVI's and an HDMI.
I don't have much to say, but if anything I'd try and get 2 monitors which are the same when running a 2 monitor setup, because with my experience in the past with multi-monitor setups, it's extremely difficult or damn near impossible to align 2 different monitors with different dimensions. That's about all I can say on the matter. Hope someone more knowledgeable on the topic turns up soon. 😛
This, if you have different models, trust me, it will look weird as ****, haha.
