GPU 1060 6GB
ADATA XPG SPECTRIX D50 - DDR4 - Kit - 16 GB: 2 x 8 GB
Ryzon 3600 XT
GIGABYTE™ AMD B550 AORUS Elite AX V2
450 SSD GIGABYTE for windows
4 TP WD HDD
Main Monitor : 27 IPS ACER VG270SBMIIPX-9325 165HZ
Second Monitor : 24 Samsung 75HZ
View: https://imgur.com/a/xzGa8TD
View: https://imgur.com/a/8F1cRC7
The problem is when connecting the 2 monitors together. Knowing that I was doing this for a year. Now for some reason the problem appeared and the main monitor does this lag and is not usable.
I thought it's the drivers and I even installed a New windows. the issue disappeared and then it appeared again.
I changed the cables. I connect the main Monitor with DP and the other one with HDMI.
Yesterday I changed the DP with a cable the changed the dp to HDMI and connected them both no issue however the refresh rate decreased to 60 FPS.
So I figured out how to solve it and reconnected again the DP and changed the refresh rate to be 120HZ and it worked fine and when i changed it again to the native resolution with 144 or 165 the issue persists.
So the Question here. Is this an issue with the monitor ? or the GPU ? If it is the monitor it is most likely still under the insurance.
Ryzon 3600 XT
4 TP WD HDD
