Dual monitor, need your help!
jaysoceee
171
i cant get my acer monitor to work with my dell...
Acer monitor is a vga cable connected, no signal..
( i remember i had to download some intel software and it worked, something like intel graphics.. )
pc specs just incase..http://pcpartpicker.com/p/YWrRwP
are you connecting your second monitor to the motherboard video out or the GPU? if your only rolling with two monitors, i recommend just hooking it to the GPU instead of dealing with multie graphics multie vender setup.
my gpu doesnt have vga =[ so yes im connecting to my mother board
your video card has analog output on its DVI-I plug. you just need an adapter. a lot of GPU venders include one in their retail boxes for GPU's. if yours did not, they are $5 on new egg.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=dvi+to+vga&N=-1&isNodeId=1
is it worth? my 2nd monitor is old like windows xp.. acer not even hd, also its just for movies,p0rn,browsing
$5 seems worth it to me for not having to deal with multiple graphics subsystems (at one point i had 3 GPU's, it didn't end well). but if you want to save 5, you need to enable igpu multi monitor support in your BIOS. after that, boot in to windows, and install the latest Intel driver for your integrated graphics, reboot and you should be set. make sure to set windows to "extend these displays" instead of its default mirrored mode to get the extra desktop space.
how do i find my intel driver? dxdiag is only showing my amd..
this link should take you to the download page for your CPU's graphics driver. https://downloadcenter.intel.com/search?keyword=4th+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+4600
you will have to enable the igpu in BIOS before you can install the driver.
wow my igpu multi monitoring was already enabled.. is it weird that 2nd monitor isnt working? (havent installed the drivers yet)
also which intel should i download? this gna be long list, but the site u gave me has it in better format.
Intel® Graphics 1
DirectX*2
OpenGL*
OpenCL*
Intel® Quick Sync Video
Intel® Wireless Display
Intel® Insider™
InTru™ 3D
Intel® Clear Video HD Technology
5th Generation Intel® Core™ Processors with Intel® HD Graphics 5500
11.2
4.3
2.0
Yes
Yes 3,4
Yes
Yes
Yes
5th Generation Intel® Core™ Processors with Intel® HD Graphics 6000
11.2
4.3
2.0
Yes
Yes 3,4
Yes
Yes
Yes
5th Generation Intel® Core™ Processors with Intel® Iris™ Graphics 6100
11.2
4.3
2.0
Yes
Yes 3,4
Yes
Yes
Yes
Intel® HD Graphics 5300 for Intel® Core™ M Processors
11.2
4.3
2.0
Yes
Yes 3,4
Yes
Yes
Yes
4th Generation Intel® Core™ Processors with Intel® Iris™ Pro Graphics 5200
11.1
4.3
1.2
Yes
Yes 3,4
Yes
Yes
Yes
4th Generation Intel® Core™ Processors with Intel® Iris™ Graphics 5100
11.1
4.3
1.2
Yes
Yes 3,4
Yes
Yes
Yes
4th Generation Intel® Core™ Processors with Intel® HD Graphics 5000/4600/4400/4200
11.1
4.3
1.2
Yes
Yes 3,4
Yes
Yes
Yes
Intel® Pentium® Processor 3558U/3560M/3561Y/G3220/G3220T/G3240/ G3240T/G3250/G3250T/G3258/G3320TE/G3420/ G3420T/G3430G3440/G3440T/G3450/G3450T/ G3460 with Intel® HD Graphics
11.1
4.3
1.2
Yes
No
No
No
No
Intel® Pentium® Processor 3805U
11.2
4.3
1.2
Yes
Yes 3,4
Yes
Yes
No
Intel® Celeron® Processor 3755U/32005U
11.2
4.3
1.2
Yes
Yes 3,4
Yes
Yes
No
Intel® Pentium® Processor 3550M/3556U/ 3560Y with Intel® HD Graphics
11.2
4.3
1.2
No
No
No
No
No
Intel® Celeron® Processor 2957U/2961Y/2970M/2981U/G1820/G1820T/ G1820TE/G1830/G1840/G1840T/G1850 with Intel® HD Graphics
11.1
4.3
1.2
Yes
No
No
No
No
Intel® Celeron® Processor 2000E/2002E/2950M/2955U/2980U with Intel® HD Graphics
11.1
4.3
1.2
No
No
No
No
No
pasow is being very helpful but it seems you are trying to do this without EyeFinity for multiple monitor support which as he suggests is more problematic. I would definitely recommend using the included adapter since generic or older adapters may not work and you are then more confused. The basic WDDM driver is required and should have been installed during an update when not connected to the video card.
it appears my link was either ineffective or you got lost on the page. as GearUp said, the generics windows auto installs should be all you need. but for some more direct links to the Intel hosted ones, in case it makes any difference.
32bit windows
https://downloadcenter.intel.com/downloads/eula/24786/Intel-Iris-and-HD-Graphics-Driver-for-Windows-7-8-8-1-32-bit?httpDown=http%3A%2F%2Fdownloadmirror.intel.com%2F24786%2Fa08%2Fwin32_153618.exe
64bit windows
https://downloadcenter.intel.com/downloads/eula/24785/Intel-Iris-and-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit?httpDown=http%3A%2F%2Fdownloadmirror.intel.com%2F24785%2Fa08%2Fwin64_153618.exe
Also, pleas check control panel > administrative tools > computer management > Device Manager > Display Adapters and tell use if your seeing two GPU's, your AMD and Intel.
For clarification on the adapter. It may be that any adapter is now suitable but that was not always the case. I still have a monitor that does not fully implement DVI that would allow copy protected content. Otherwise it works and DVI-I should not be a problem. DisplayPort is still not accepted. What difference there could be is unknown and the desktop should still display.
