[SOLVED] Dual monitor setup help
Justhea
44
Hi,
so i was trying to connect my vga monitor to my gpu but it doesnt have vga however my motherboard has a vga but no on board graphics.
is there some way i can use the vga on my motherboard and do 2 displays?
Why not buy a adapter?
It will be much easier.
Do both of your monitors have VGA output only?
What monitors do you have?
What GPU do you have?
I have a gtx1050 ti with dvi hdmi and dp
my other monitor doesnt have any ports just vga
my motherboard is an msi a320m pro e
my cpu is a ryzen 5 2600
