Dual monitor & TV - GPU recommendation
bofla
APPROXIMATE PURCHASE DATE: In a month BUDGET RANGE: $200-$400
USAGE FROM MOST TO LEAST IMPORTANT: Dual monitors running at 1920x1200 and a 1080p. I guess anything that can run this can run games just fine.
CURRENT GPU AND POWER SUPPLY: Gainward GeForce 560Ti 1GB, Chieftec 850w
OTHER RELEVANT SYSTEM SPECS: AMD FX-8120 on Asus M5A97 R2, 8GB of RAM. Dell U2412M and HP LP2475w
PREFERRED WEBSITE(S) FOR PARTS: n/a, need to look for dealership in my country COUNTRY OF ORIGIN: Serbia
PARTS PREFERENCES: Never had an AMD rig before, this is the first one, and never had AMD GPU. I'm not against it anymore
OVERCLOCKING: No SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1920x1200 times two, 1920x1080
ADDITIONAL COMMENTS: I need to replace my current card as it seems doggy at best, and VGA output flickers on monitor top with relatively bad quality picture which shouldn't be doing. I have two 24" monitors that do 16:10, and a TV for watching moves. I'd like to connect this all to my computer, not yet ready to dive into a full blown HTPC (no room). I'm looking for a card, most cheapest I can get that will run this. I've had my eye for a while on a Palit GTX670 Jetstream 2GB, but I'm not sure if that'll do. I'd want TV output over DVI or HDMI. (I have a convertor cable ATM)
Thanks!
