Hi,
I am a bit of a noob when it comes to wiring.
For spec details - My current build log is at http://www.tomshardware.com/answers/id-3668137/build-log-duncans-rgb-aussie.html
I currently have 2 x EKWB D5 PWM Water Pumps and the Grid V3+ Fan Controller. I was wondering how I connect the pumps up so they can be controlled? I beleive if we answer the below 3 questions it will solve my problem.
Question 1: Can the Grid V3+ control the PWM D5 Pumps as well as the fans (Obviously it will be on a different channel to the fans).
Question 2: Do I have to plug in both the molex and PWM cables when operating my water pumps or can I just use the PWM cables.
Question 3: Is the W_PUMP+ port on my mobo PWM controlled.
With the above 3 questions answered what option should I use.
Option 1:
-Connect 2 x PWM Cables (D5 Water Pump) to the W_PUMP+ port on my mother board using a Y-Splitter.
-Connect 2 x Molex Cables (D5 Water Pump) to the PSU.
-Control all fans to the Grid V3+
Option 2:
-Connect 2 x PWM Cables (D5 Water Pump) to the Grid V3+
-Control all fans and the 2 x D5 water pumps with the Grid V3+
Option 3:
One of the above 2 options without the Molex cables plugged in.
Option 1:
Option 2:
Option 3:
