Dual SLI: Will air cooling suffice enough for two ASUS DCUII OC NVidiat GTX 760's in an NZXT Phantom 410 case?
railerswim
6
As above, I really don't want to spend the money but I do know that all 760's get hot but the ASUS DCUII OC variant stays cooler than the others.
If I need to switch my CPU to watercooling I will do it (it's an AMD FX-8350 4 GHz 8-Core)
I currently have the same set up(GPU and Case). I've been tweaking for about 2 weeks now. Use the 2nd GPU for your monitor output and change the fan curve on the 1st to a constant 80%. You should get good results depending on how well your cables are managed. As of now I get a max of 59C on the lower card And 68C on the upper(23C ambient). This is while running heaven benchmark on ultra with tessellation for 2 hours. As for water cooling... there are no direct fit waterblocks for this GPU yet. It is non reference.
postman81
75
