[SOLVED] Dual system cooling corsair 1000d
Feb 8, 2019
I'm planning on building my own custom pc (at some point in life, im still a jobless high school freshman) and I need help with how to make a water cooling system that will fit inside the case and cool all of the gpus and cpus I plan on using. (I would also like a parts list, if possible)
Heres the list of parts i plan on using:
https://pcpartpicker.com/list/MLycsZ (I plan on doing a dual system and pcpartpicker won't let me use two motherboards at the same time)
Other set of parts (for second motherboard): https://secure.newegg.com/Shopping/ShoppingCart.aspx?Submit=view
You could build something incredibly impressive and game worthy without such a high budget.
Case $179.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16811854080&ignorebbr=1&source=region&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Cases+%28Computer+Cases+-+ATX+Form%29-_-N82E16811854080&gclid=EAIaIQobChMIzfed14mt4AIVl43ICh3_6A3oEAQYAiABEgIs6PD_BwE&gclsrc=aw.ds
Builds
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($164.99 @ Amazon)
Motherboard: Asus - ROG Strix B450-I Gaming Mini ITX AM4 Motherboard ($149.52 @ Amazon)
Memory: G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($109.99 @ Newegg)
Storage: Crucial - MX500 500 GB M.2-2280 Solid State Drive ($67.85 @ OutletPC)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive ($59.89 @ OutletPC)
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING Video Card ($348.99 @ SuperBiiz)
Total: $901.23
Generated by PCPartPicker 2019-02-08 16:28 EST-0500
PSU
Power Supply: EVGA - SuperNOVA G3 1000 W 80+ Gold Certified Fully-Modular ATX Power Supply ($149.99 @ Amazon)
Total: $149.99
Generated by PCPartPicker 2019-02-08 16:29 EST-0500
Monitors
Monitor: LG - 29WK600-W 29.0" 2560x1080 60 Hz Monitor ($239.99 @ Newegg)
Total: $479.98
Generated by PCPartPicker 2019-02-08 16:30 EST-0500
Peripherals
Keyboard: Corsair - K55 RGB Wired Gaming Keyboard ($46.99 @ Amazon)
Mouse: Corsair - M65 PRO RGB FPS Wired Optical Mouse ($38.80 @ Amazon)
Headphones: Kingston - HyperX Cloud II 7.1 Channel Headset ($93.90 @ Amazon)
Total: $359.38
Generated by PCPartPicker 2019-02-08 16:31 EST-0500
Total: $2971.80,
If you plan to turn this into a "real thing" then come back when you have the money in hand.
Planning a build, especially one as absurd as this, is utterly pointless unless you are ready to buy now.
Additionally, nothing about that build is necessary, its quite obvious you just threw expensive parts together.
