Dual W2K Pro processor load
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hello,
i can only get a total processor load of 60% while using W2K prof. One CPU ~100% and the other CPU ~30%.
The goal is: 2x ~100%
The application supports both processors.
You may want to try setting different affinities. Check out <A HREF="http://www.jsiinc.com/tip2100/rh2191.htm" target="_new">http://www.jsiinc.com/tip2100/rh2191.htm</A> for more info...
