Duel Monitor FPS Issue (under certain conditions)
novaranger
46
Greeting my fellow computer enthusiasts. I've been dealing with a rather annoying and constant issue for nearly a year now(started randomly) that was not present for the first year of owning this card..
Whenever I run Duel monitors(after a system restart) Everything will run smoothly without any issue's whatsoever, and once I start doing Graphics intense things(like games) usually about an hour the Game will crash and suddenly my entire system will be running at a couple FPS until I either disable the second monitor OR disable Aero(Desktop composition). Single monitor usage is perfect but as soon as the second one is added in things go crazy. UNtil this issue is resolved im stuck either rebooting my computer every hour or 2 to fix the issue, disable my second monitor, or disable desktop composition(not an option since software overlays are used for programs I use)
Some system info
Asus Maximum VIII Hero Alpha Motherboard
Intel I7 6700K (stock clocks) Water cooled
MSI RX 380 4GB Graphics card Air cooled
GeIL SUPER LUCE 16GB @ 2877mhz(cant remember exactly)
Troubleshooting attempts
I've removed all Graphics drivers and have done a fresh install(most recent version) with the issue persisting after 2 hours of gaming and Crashing causing the FPS issue to start again.
Removed the Graphics card and cleaned it (barely dusty)
Removed any possible possible overclocks
Memory was tested 2 months back while doing overclocking on full system No issues were found
Here is the Crash report. It seems the ntdll.dll is the issue but past this i dont know what to do/where to look, other than its an issue with Heap corruption
**Faulting application name: Name_removed_LuL.exe, version: 0.0.0.0, time stamp: 0x59deeb8d
Faulting module name: ntdll.dll, version: 6.1.7601.23796, time stamp: 0x590296ce
Exception code: 0xc0000374
Fault offset: 0x00000000000bf3e2
Faulting process id: 0x1b2c
Faulting application start time: 0x01d3461bfdf985b2
Faulting application path: D:\Name_removed_Lul\Name_Removed_Lul.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 08796de2-b235-11e7-8fbd-c8ff2802489e**
