Dust Remover Spray is it safe for cleaning pc components?
whiteknights
777
hello.. i bought Dust Remover Spray from radioshack because i have a stuck dust on my pc from inside, wanted to know if its safe to use it on mobo, cpu and GPU?
Just keep the end of the nozzle at least six inches from the hardware, use short bursts, and let the can warm up if it gets cold. Do it outside if you can, the dust will make a rather unpleasant cloud.
Also use something to hold the fans so they don't turn when you hit them with the canned air.
