dvd, cdrw problem -drivers??
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
ok, this is the problem. (i already reinstalled windows). the drives work
just fine - they both read, and the rw writes, - data and audio. i install a
cd burning program that i want to use for it's mp3 editing, and the drives
screw up. i think maybe the drivers are conflicting??? i want to load my
choice of drivers on startup, depending on whether or not i want to use that
program, but i can not figure out how to do it.
> work just fine - they both read, and the rw writes, - data and audio.
> i install a cd burning program that i want to use for it's mp3
> editing, and the drives screw up. i think maybe the drivers are
> conflicting??? i want to load my choice of drivers on startup,
> depending on whether or not i want to use that program, but i can not
What program?
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
the program is Cakewalk Pyro 2004
> What program?
> <- Shenan ->
> audio. i install a cd burning program that i want to use for it's
> mp3 editing, and the drives screw up. i think maybe the drivers are
Shenan Stanley wrote:
> What program?
As this seems to be related to the application itself (and there is likely a
way to install it and not take over CD burning - as there is for all other
applications of this type - a matter of association really) - you should
talk to those who made the application and/or use it:
pyro 2004 Support
http://www.cakewalk.com/Support/Pyro/PY2004.asp
Ask your specific question here:
Cakewalk Forum:
http://www.cakewalk.com/forum/tt.asp?forumid=23
<- Shenan ->
