I have a Lite-On iHAS624 sATA DVD Combo drive. When I bought it I had Vista installed and it worked great without any issues. I have sinced wiped my computer and installed XP pro w/ SP3 instead (because I only have 1gb of RAM I find the XP runs faster overall but that is neither here nor there).
In Windows XP the drive shows up under My Computer as a CD-ROM drive, or DVD-RAM drive. If I right click and go to properties there is no Recording tab that shows up. I am not able to use the built in XP burning tool to burn files to a CD, and most third party software like Roxio 7 and up also will not detect it as a drive that I can write to.
However, some programs do use it to burn just fine. For example, I can use iTunes to write a CD using the drive. I am also able to use Alcohol 120% to burn image files without any problems at all.
I have tried to remove the device from Device Manager and let windows reinstall it. I have also tried to get up to date drivers for by letting windows search for it. I downloaded a tool from the manufacturer website to update firmware and drives but that also did not resolve the problem.
Is there anyone out there that has a suggestion besides having to go back to vista or get a new combo drive?
