Does the device not read the DVD at all, or can you see the files on it but not play it as a movie? In the latter case, you have to install the proper software on your new system.
If, on the other hand, you are still running the old OS disk and / or the drive can't read data DVDs, it seems most likely that the drive is broken.
Can you read _any_ DVD now, either data or movie?
