Dvi d cable
nisarg123
31
Dvi-i dual link cable will work with 1050ti oc ?
my monitor supports till 75 hz
my monitor has Dvi-I dual link slot
my gpu will come in next 2 days or so
If the GPU card has a DVI-D dual link output, and your cable is a DVI-D dual link cable, and your monitor has a DVI-I dual link input, then it will all work fine other than you will not have any analog input on the monitor which is what the other four pins that are not present on the DVI-D dual link connector but ARE on a DVI-I dual link cable or connector, are for.
DVI-D DL GPU card + DVI-D DL cable + monitor with DVI-I DL input = OK.
DVI-I cable with DVI-D input would not work because the four extra pins on the cable would not have anyplace to plug into. You don't have to worry about this with your setup though.
i zoomed in my gpu pic from amazon it has dvi-d dual link so i have vga so should i buy dvi-d or i what to do ? pretty much confuse
