I need help with the DVI on my graphic, XFX Radeon 6850 ( http://xfxforce.com/en-us/Products/Graphics-Cards/AMD/AMD-Radeon-HD-6000-Series/AMD-Radeon-HD-6850.aspx )
It lists :
Output - DL-DVI:1
Output - HDMI:1
Output - mini DP:2
Output - SL-DVI:1
So I basically have two DVI's on my graphics card, but each one is different according to the list. Looking at the picture and my physical card, it seems that it runs on DVI-Dual Link since it matches the picture on wiki (http://en.wikipedia.org/wiki/Digital_Visual_Interface). But, then again, I don't want to be wrong.
If the DVI's are different, then can you please tell me which one is which? Not only that, but I also need to know since my current monitor only supports VGA - meaning I'll need to go buy a VGA adapter to convert it to DVI so I can finally get my rig up and running.
Any insight will be greatly appreciated. Thanks in advance!!!
It lists :
Output - DL-DVI:1
Output - HDMI:1
Output - mini DP:2
Output - SL-DVI:1
