P parasahuja68 Jul 13, 2018 1 0 10 Jul 13, 2018 #1 Can I connect my GTX 1060 6GB to my AOC F19s monitor through DVI cable.
Solution Dunlop0078 Jul 13, 2018 Yeah of course if your 1060 has a DVI-D port, I believe most do. You will need a DVI-D dual link cable.
Dunlop0078 Titan Ambassador Feb 13, 2014 13,306 146 70,990 Jul 13, 2018 Solution #2 Yeah of course if your 1060 has a DVI-D port, I believe most do. You will need a DVI-D dual link cable. Upvote 0 Downvote Solution
Wolfshadw Titan Moderator Aug 3, 2006 28,224 1,514 133,290 Jul 13, 2018 #3 Specs for that display only show a D-Sub 15 (VGA) input. That's analog only. Since the GTX 1060 does not have an analog output, you will need to purchase an active DVI-D to VGA converter. -Wolf sends Upvote 0 Downvote
