DVI - VGA adapter not working!
Sixty_
4
Hey, for some reason my adapter dont work. Its DVI-I>VGA. My graphic card is gigabyte radeon hd 7790 2gb OC which have both DVI. I have this adapter https://images-na.ssl-images-amazon.com/images/I/31bHvdI5ILL.jpg and it doesnt work. What is the solution? I alerady installed drivers to this card. Card is working, cuz i tested this on TV with HDMI cable. This is back of the card: https://s5emagst.akamaized.net/products/1296/1295595/images/res_aec42cefdb2a7d251ac88ee7bc09bd68_450x450_9spr.jpg
If there any mistakes, sorry for my english its not my native language.
If you are plugging the adapter into the DVI-I port (left), it should work. (Obviously you wouldn't be able to plug it into the DVI-D port (right) because it is missing the analog pin holes)
I would consider possibly a bad adapter or VGA cable. Unless your monitor is bad.
