DVR capabilities of system build-advice needed
robistro
53
Hello all,
I am in the process of selecting parts for my first HTPC build. I am wanting to be able to DVR my Time Warner digital cable, and to be able to DVR one channel while watching another.
Below are my concerns....
1. Is this motherboard/cpu setup capable to achieve what I am wanting to do? http://pcpartpicker.com/p/2ICa
2. Do I need to add a separate video card for HD tv to the motherboard?
3. Is this separate external box ok? http://www.amazon.com/Hauppauge-WinTV-DCR-2650-Tuner-Cable/dp/B005FPT38A
Any and all advice, suggestions is appreciated!
Thanks
ok considering everything, i think this is the best one to go with:
PCPartPicker part list: http://pcpartpicker.com/p/xKOV
Price breakdown by merchant: http://pcpartpicker.com/p/xKOV/by_merchant/
Benchmarks: http://pcpartpicker.com/p/xKOV/benchmarks/
CPU: AMD A4-5300 3.4GHz Dual-Core Processor ($49.98 @ Outlet PC)
Motherboard: Asus F2A55-M/CSM Micro ATX FM2 Motherboard ($79.99 @ Newegg)
Memory: Kingston HyperX 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ NCIX US)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($64.99 @ Amazon)
Case: nMEDIAPC HTPC 1080P HTPC Case ($66.98 @ Newegg)
Power Supply: Corsair CX 430W 80 PLUS Bronze Certified ATX12V Power Supply ($29.99 @ Newegg)
Optical Drive: Lite-On...
robistro
53
Any suggestions for a mb and cpu on this build our friend Ice put together? http://pcpartpicker.com/p/xL1L He already changed out my crappy powersupply.
Thanks guys !
robistro
53
THANKS much for the advice Ronin....thats good info
Thank you - I hope it saves you hours of support calls, searching through forums, etc....
I am a highly technical person - and you would think these setups are "plug and play"....very few places to get information. I purchased SiliconDust, but through searching the Hauppauge, Ceton and SiliconDust forums, I have found many good tips. There aren't many good WMC websites/forums that are up to date...
It took about 2 months of struggling to get the system working perfectly....but TWC now has my 2 cable boxes, and I have $60 per month in my pocket. In less than a year, the computer, digital tuner and XBox360 are paid for....
robistro
53
Thats exactly what I'm working toward....any tip or info you could forward me about WMC setup..etc? or when I finally get around to building hopefully I could look you up for some assistance?
robistro
53
Hey, thanks for your last build and looking up info....wolf doesnt like my cpu/motherboard setup. Can you find me a more sufficient setup? I'm sure you saw his post.... thanks again your awesome!
robistro
53
Hey Ronin, what type of remote are you using? can you suggest any for me?
PCPartPicker part list: http://pcpartpicker.com/p/xLFW
Price breakdown by merchant: http://pcpartpicker.com/p/xLFW/by_merchant/
Benchmarks: http://pcpartpicker.com/p/xLFW/benchmarks/
CPU: AMD Athlon II X4 631 2.6GHz Quad-Core Processor ($64.99 @ SuperBiiz)
Motherboard: ASRock A75M-ITX Mini ITX FM1 Motherboard ($89.99 @ Newegg)
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1333 Memory ($38.99 @ NCIX US)
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case ($34.90 @ Amazon)
Power Supply: XFX ProSeries 450W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($34.99 @ NCIX US)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($22.98 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $441.81
(Generated by PCPartPicker 2013-01-15 15:47 EST-0500)
robistro
53
man Ice! your really bustin out the builds! lol Hey, wolf suggested a AMD FM2 cpu and a compatible 'Micro' ATX motherboard to keep my costs down... You already fixed my power supply. which by the way I had no idea it was junk. Thanks!!! and thanks for keeping touch with your expertise.
PCPartPicker part list: http://pcpartpicker.com/p/xLMG
Price breakdown by merchant: http://pcpartpicker.com/p/xLMG/by_merchant/
Benchmarks: http://pcpartpicker.com/p/xLMG/benchmarks/
CPU: AMD A4-5300 3.4GHz Dual-Core Processor ($54.99 @ Newegg)
Motherboard: ASRock FM2A75 Pro4-M Micro ATX FM2 Motherboard ($81.97 @ Newegg)
Total: $413.79
(Generated by PCPartPicker 2013-01-15 15:58 EST-0500)
Wolfshadw
http://www.newegg.com/Product/Product.aspx?Item=N82E16880101002
This is very similar to the one I have. The PC I am running is actually a HTPC designed by HP in 2006....I have replaced the tuner card that came with it, but the remote is almost identical.
Some people swear by the Logitech Harmony Remotes like this one:
http://www.newegg.com/Product/Product.aspx?Item=9SIA0FU0CW4227
I didn't think it was worth the price....I turn the TV on with the TV remote, and then put it away and use the WMC remote...
Thank you Wolf! I have some more reading to do!
Other: Hauppauge WinTV-DCR-2650 Dual Tuner Digital CableCARD Receiver ($99.99)
Total: $544.87
(Generated by PCPartPicker 2013-01-15 16:41 EST-0500)
robistro
53
BIG THANKS to Ronin,Iceclock, and Woflshadw! you guys ALL had very good information! I cant select a 'best answer' because they were all equally important! however a Icey did put a lot of effort into putting together build packages.
If I have any questions I'll look you guys up again. I'll start putting together the parts list and ordering as soon as I can. I'll let you all know when mission is completed. Thanks again peeps!
