nukemaster :
They used 12 volts because there is a loss(heat) of power when you step up 12 to 230 and then another loss(the heat your psu makes is a loss of power) when they step the 230 back down to 12. They save them self anywhere from 30 to a whooping 50% power by keeping the system 12 all throughout.
What PC do you have that needs 600 watts?
My system takes 330 watts from the wall(would be a good 20% less if i did the 12 volt trick they did...more so if i went solar panel step up to 120[the voltage here] and back down to 12. that would put me in the 30-40 percent range)
Here is the system i speak of:
Case: Antec 900
PSU: OCZ 700watt
Board: P35 DS3R
CPU: Q6600 @ 3.00
CPU cooling : Zalman 9500 @ 500-2200 rpms(PWM)
Memory: 2x 1024MB ,2X 512MB @ 4,4,4,10
Video: 8800GTX 600(core) 1400(shader) 900 x2(memory)
Storage:
2x WDC 250gig (Raid0)
2x Seagate 320gig(Storage)
2x Seagate 500gig(Storage)
1x 500gig Seagate (Backup-external) - Not in the power count
Optical drive: Samsung SH-W162
KB/Mouse: Logitech Elite wireless(MX 700 out of service), G9 Mouse
TV card: PVR 250
Sound: Creative SB Audigy 2zs
Screen: Samsung 950b (LCD)(not included but it takes 30 watts)
Speakers: Altec Lansing Select 641(12-30watts for average listening)
You may get away with less power then you think....the trick is to store enough power in the batteries for night time...and have at least an extra panel to charge and run things on cloudy days....
Case: Antec 900
PSU: OCZ 700watt
Board: P35 DS3R
CPU: Q6600 @ 3.00
Storage:
TV card: PVR 250
hi
i'm not calculating my watt only i thinked this is the maximum
You have a great configuration
My configuration is same like your.
PSU: Mercury 550 watt
Board: m2n31-sli deluxe
Cpu: amd x2 4600+ (2.4 ghz)
Cpu cooling: what was in the box but i want to change to zalman (to hot the cpu)
Memory: 2x512(kingston CL5) 2x1gb (kingston cl5)
video: Ati sapphire x1650xt 256 600/1400 mhz
Storage: 2x 200gb maxtor
optical drive: nec dvd-rw nd-3540A
kb/mouse Logitech MX revolution
TV card: Leadtek winfast 2000xp global
sound:1 i mainboard and 1 c-media 5.1(for tv card)
screen: - fujitsu siemens LCD 19" L-191
- 15" crt (for tv card)
speakers: Genius SW-HF 5.1 5000
Exist some kind of software what calculating my pc watt usage or i need to add all component one by one?
thanks for the help
