EasyBCD not starting up.
Abhishek Sakibanda
12
I tried installing Remix OS on my laptop a few hour ago, but I had done something wrong to the PC.
When wanted to retry the whole process from scratch, I couldn't open the application. My bootloaders are still appearing when I switch on my PC and I wanna delete the other bootloaders except for the default Windows Bootloader.
Need help asap.....
Guys,I too exactly had the same problem.....Atlast found the solution:
1)Download an earlier version of Easy BCD
(or)
2)Try installing Beta versions if any....
Hope it works..It worked for me....
Yes, it is 2.3 and I have reinstalled it several times but still no luck.
Did you get it resolved Abhi? I have the same issue, 2.3 wont run on Win10
.nope. Still trying to fix it. It worked at the time I installed it the first time but now its not even starting... 🙁
(or)
