G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
Hi,
I'm interested in buying an ECS K7S5A-Pro motherboard, and would like
feedback from you all regarding this board. Also, I have some specific
questions:
1) I was wondering if any of you who have or had this board happened to run
HDTach with it and an ATA100 drive? If so, what kind of numbers did you
get?
2) I'll probably initially be running a Duron CPU, and was wondering whether
the BIOS allows you to lower Vcore?
If the standard BIOS doesn't, do either of the other BIOS (Cheepo, etc.)?
I'm mainly interested in getting a stable system that's relatively
cool-running and quiet, and have had success with Abit motherboards lowering
the Vcore, and if I get the ECS, I'd like to try the same.
On that note, I'd be interested in hearing what kind of CPU temps you all
are seeing. I have one Asus board (A7A266) that absolutely runs CPUs hot,
and with my testing, I believe this is because the board is putting out a
relatively high Vcore (higher than the BIOS setting).
3) I'm kind of confused about the LAN. The specs indicate that it is
"optional", and it looks like the web stores just copied the specs. Does it
come with an onboard NIC or not?
Thanks,
Jim
Hi,
questions:
get?
Thanks,
Jim
