Question Edifier r1280t with subwoofer
ortzpvp_
Commendable
Mar 2, 2018
5
So I was wondering if I could connect my old sub woofer (GXT 628 Tytan 2.1). I have the Edifier r1280t right now, and I still have the sub of the other speakerset. Is there any way I can make them work together without a lot of hard stuff, since I'm not quite the electrician...
Thanks,
Kevin (OrtzPVP_)
delaro
Judicious
Ambassador
There are a few ways actually depending on your motherboard.
  • Hook the Tytan up to the front audio jack
  • Hook the Eddy's to the rear audio jack
  • Tell windows to output them simultaneously. "Easy to set up in Windows 10.
OR
  • Look at the back of your motherboard and see if you have a C\Sub jack and hook the Tytan there.
  • Hook the Eddy to the Read audio output and tell windows to use them both if it ignores the Tytan.
OR
Run a USB to 3.5mm X 2 splitter. These have no feedback when compared to a 3.5mm splitter and won't require you to fiddle with windows to output to multiple sources.
