EKWB Intros PWM Compatible EK-DCP 4.0 Water Pump
Here Iam live the temps is about 45ºc i think the water will hit more than 65ºc fit an 3820 and 290x. this will heat to death
At Amdlova, 65C would be very poor for water temp in a custom loop. With my fx 8320 at 4.8Ghz 1.55vcore and a gtx 470 I'm sitting at 26.6C water temp. At full prime load and my fans all turned up my water sits at right about 30C. Also if my water ever hit 65C my cpu would be overheating since the max core temp is only 62C.
Assuming I am reading the product label correctly, it is rated for a Maximum of 21.6W (12V x 1.80A).
Not a bad price for a quality pump and the noise savings would be definitely appreciated.
