[SOLVED] Electric shock noise when powering on PC
yes, pressing button on front while recording the back. can't tell exactly where the shock noise is coming from, may not even the be power supply
Well.. I will say that's a VERY OLD power supply. Might as well just swap it out because I'm sure it can't be at it's top performance.
Judging by the video it looks like there's a relay or something flicking inside that power supply at the same time the noise can be heard. Maybe it's one used to switch between 120v and 230v automatically? I can't say for sure, just an educated guess.
now that you mention it, I do see the movement in the video. Good eye, I'll check that out.
