1. Im a very "careless" person, can drop anything like usb, hard drive, phone, etc. So I make a custom box with elastic foam inside to protect my external hard drive if it drop from my hand/desk.
View: https://imgur.com/YRUsizH
BUT the main problem is, it increase heat at least 5 Celcius. So I want to put custom usb fan below this cardbox.
View: https://imgur.com/IZ1eEMG
Question: Is it safe to put a fan below "foam wrapped" external drive? How about electrical static issue?
2. I have cheap laptop, with bad cooling system. 60-70 Celcius when browsing. So I bought a laptop vacuum Taffware. It helps, it can reduce my processor temp 10 Celcius. But, is it safe?
View: https://imgur.com/oqBsXQ2
3. Blow dusty PC with blower can harm your device because of electrical static. Myth or Fact?
Laptop model: ASUS VivoBook X441UBR
Desktop spec:
ASUS TUF Gaming B560M
Core i5 10400
RAM 2x8GB 2666Mhz
GTX 1050 Ti
SSD Samsung 256GB
WD Blue 1TB 3.5"
Desktop spec:
Core i5 10400
RAM 2x8GB 2666Mhz
GTX 1050 Ti
SSD Samsung 256GB
WD Blue 1TB 3.5"
