N nastyboy_2000 Jun 29, 2018 4 0 10 Jun 30, 2018 #1 I just want to know if i have the right slot to plug this bad boi in. Im pretty sure i do but i wanted to be sure so im asking you guys.
Wolfshadw Titan Moderator Aug 3, 2006 28,223 1,514 133,290 Jun 30, 2018 #2 Yep! You're good. The Elgato HD60 Pro requires a PCI-Ex1 expansion slot. Your motherboard has two; one above and one below the primary PCI-Ex16 expansion slot. You'll probably need to use the one above. -Wolf sends Upvote 0 Downvote
