Archived from groups: rec.games.pinball (
More info?)
I agree with frenchy.
I would also add again, that I clean all that with a rag dampened with wd40.
keep in mind that this is 30-40 year old metal that is prone to rust and
wd-40 blocks moisture and oxygen. clean the springs too.
you can even put white lube on the edges of the score motor disks and a thin
layer of same on the wiper boards. Light oil on the step-up pawls of the
various units is also a GOOD idea.
Do all the above every 6 months. Nobody ever does, but that's what the book
says you should do.
billb
the stock market is one giant electronic chain letter.
Governor Henry Blasdel, Nevada's first governor after statehood, voiced his
opposition to the proposed new act in the strongest of terms: "I know of no
greater vice than gambling. It is against public morals. It saps the very
foundations of society. It induces intemperance. It begets idleness. It
fosters immorality. It multiplies crime. It leads to reckless extravagance.
In short, it is the root of all evils."
"frenchy" <mf101723@msn.com> wrote in message
news:1124054198.503981.239590@g44g2000cwa.googlegroups.com...
> I was referring to the plastic drop target itself or anything it slides
> against. Yes that pivot in your picture is perfectly fine to be
> cleaned of dirt and rust and then a drop of light oil applied. (But
> not to the other joint with the fiber link on it)...Frenchy
