i dont think u can achieve more than 60Hz on that monitor with HDMI,i think u have to use displayport.Check the prices of HDMI to DisplayPort adapters.Thats your only bet,except ofcouse buying a modern gpu with DisplayPort.nope, it only has HDMI and 2 other ports, maybe they're called DVI or something
nope, it only has HDMI and 2 other ports, maybe they're called DVI or somethingis the connectivity via DisplayPort available?
What i mean is does your gtx 750ti have a DisplayPort slot,if it does connect it to the monitor via DisplayPort.
with my old gpu i had 120hz via hdmi thoughi dont think u can achieve more than 60Hz on that monitor with HDMI,i think u have to use displayport.Check the prices of HDMI to DisplayPort adapters.Thats your only bet,except ofcouse buying a modern gpu with DisplayPort.
my previous gpu was rx 5700xt nitro+ and my current one is a gtx 750ti (oem)What brand/model was your old card and the new one?
I think i know what the problem is.my previous gpu was rx 5700xt nitro+ and my current one is a gtx 750ti (oem)
probably 5700XT diedMay I ask why you got rid of your 5700xt for a 750ti?
