EML VIRUS problem
Follow the steps:
1- Restart your computer in safe mood
2- Search the files with the extention '.eml' Click start and then click at search type .eml only in the search box and select all drives for it then search and delete all the files.
3- Type regedit in RUN and then OK.Press Ctrl + F and type runouse then find it and delete all the entries which showed up.
Get Bitdefender antivirus or any other paid antivirus for keeping your system safe.
Follow the steps:
thre is no option of deleting
i right click then there is no option of deleting
ANTIVIROUS DELETED IT.i press CTRL+F then type runouse then click find next.CAN YOU TELL ME WHICH THING I HAVE TO FIND
looks like your machine is full with virus, files are mostly skipped in free version of antivirus. If you can afford a paid one, it would be best. Last suggestion would backing up your important data and reinstall windows by formatting all drives if your problem doesn't get solved with antivirus. Another tool you can use is Malwarebytes. I hope you get your problem solved with antivirus and malware program.
