Enable fan control settings on GA-970a-UD3P
Kostas_11
Commendable
Jan 12, 2017
28
As i have seen in some videos this motherboard has the ability to switch the cpu_fan voltage. I just got a Kraken x61 and i must put the cpu_fan at 100%. But cpu_fan settings doesnt appear on my BIOS. Does anyone know why?
Do this program have to run everytime so the changes are kept? Cant i just put the fan somehow to the maximum via BIOS settings?
Indeed you are right! thanks for that. But then you have to change the values of the "Slope PWM" i guess. Cause in CPU Fan Speed Control you have the options: Disabled,Silent,Normal. Do you know how to make it run on full speed?
