Question Encountered the same problem on PC with three PSUs ?
Feb 2, 2021
4
Hi tech experts, I landed on this site since i cant find any updated forums in this case. I looked at every thread related in this problem.
I have here a System Unit running in good condition for 2 years, and stopped 3 months ago.
Problem: cannot boot up with single press of power button.
Next day after shutting down the pc properly , pressing the power button cannot bootup the system (Usb ports have power)
Tried fixes:
reseat every accessories in mobo-cant solved
Change CMOS battery -failed
Change Psu (1)- solved
-PC boot up , played music , play games.,, I shutdown it after .
-on the next day i tried pressing the button, the problem returns
And pc wont boot up again.
-change to new PSU(2) and its booting up again. And on the next day, the problem returns.
Doing Paperclip test on 3 PSUs and all are working.
Any help from you guys will save me time and money and prevent me from buying new gear again. I dont want to buy new PSU again.
what are specs of the PC.
Its not the PSU. No one is that unlucky, so its something else in PC that is cause.
i expect you would find you can rotate between all 3 PSU. try a different one each day and they would work.
I could guess its the motherboard
Do you power on using case button or have you tried just starting via motherboard? figure out where fault is.
Reactions: Revol012
I tried back the other previous 2 PSU on same motherboard but it cant boot up anymore. I tried also just the motherboard+CPU+RAM for testing purposes on other new Psu and it will boot just like the other three, and after a day of rest(shutdown correctly), It wont boot up again. That's what i suspect too the motherboard suddenly fails after a long rest of no power) ,
Mod Edit: By the way, I ran into Asus b450 ryzen 5 8GB memory sticks and ssd 120gb, NO GPU or other accessories inserted.
What CPU are you using in this system?
I deleted my previous comment answer "with mod edit" that was for other site thread.
Here is the actual specs of Pc.
CpU: amd A6 6400
Psu: generic 750(same issue on 500 and 450W)
Ram 2x8gb kingston (tried also booting without ram and hdd -no effect)
I Tried all PSu mentioned and it booted up but After all day rest , it wont boot up, again. As i mentioned doing paperclip test on all PSU after experiencing problem an all are good.
