Enermax Ostrog GT water cooling
Tomas Studnicky
28
Hi guys i would like to ask if it is possible to fit water cooling in the Enermax Ostrog ECA3280A-BL
I would just like to cool the cpu so i would just use a single radiator with a fan and so would it fit in the enermax??
if you want to put 2 radiators on only one pump you will need to built a custom watercooling loop, and that can became 2x expensive than 2 separate ones.
temperatures will be fine as long the system is well builded
and if i also wanted to cool the GPU gtx 970 would that mean i'd have to get a bigger radiator or would a Corsair H80i do?
Okay so the 140mm would cool my GPU and my CPU? and do you know any good once?? and also do you mean the front like here? https://ctrlv.cz/Lng6
yes, in your front you can still have the blue fans and an 140mm radiator there for GPU cooling and in the back of the case you can fit a 120mm radiator for the cpu cooling. make sure you have the intake in the front of the case and in the rear the exhaust for maximum cooling performance
Okay thank's but can i connect both of them to 1 pump like can i connect the two radiators together and then reservoir and pump and stuff?? also the temperature will be fine when playing GTA 5 on maxed out settings?
