[SOLVED] Enough power for rtx 2070 super?
Feb 10, 2020
Question for the smart guys, just ordered the Gigabyte rtx 2070 super windforce and was wondering if i need to upgrade my psu while im at it, i wont be overclocking the card.
Specs:
i7 8700k not overclocked
MSI Z-370 A Pro
16gb ddr4 3000mhz
Seasonic 620w bronze rated psu
CM Hyper 212 cpu cooler
120gb ssd
2tb hdd
3 rgb case fans
2 rgb strips
I’m worried i dont have enough power for this card, want to make sure.
this is the card i bought https://www.newegg.ca/gigabyte-geforce-rtx-2070-super-gv-n207swf3oc-8gd/p/N82E16814932213
Specs:
MSI Z-370 A Pro
16gb ddr4 3000mhz
120gb ssd
2tb hdd
3 rgb case fans
2 rgb strips
PCPartPicker Part List
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.99 @ Best Buy)
Total: $119.99
Prices include...
Specs:
MSI Z-370 A Pro
16gb ddr4 3000mhz
120gb ssd
2tb hdd
3 rgb case fans
2 rgb strips
Total: $119.99
Generated by PCPartPicker 2020-02-10 15:04 EST-0500
Without overclocking, your system will max out somewhere around 400 watts. You'll be fine with the PSU you have for now. Upgrading to a newer, higher quality model would be a good way to protect your high-end parts, but it's not like you need to rush out and get it immediately. Your Seasonic 620W is an older design but has enough power and it has the required PCIe power connectors for the RTX 2070 Super. When you're ready to upgrade, here's a few great models to consider-
650 Watt PSU's
