Enquiry for Best Water Cooling Route
alienalvan
Commendable
Dec 26, 2016
8
Well i'm having a hard time to choose the best WC loop for my PC & i've a few option in mind, please based on below options choose the best cooling performance & explain why you think it's perform better compare with the other options.
Option A
Option B
Option C
Not to mention 1 isnt possible in the first place. The GPU flows from one side of the block to the other, therefore you cant have all the inlets and all the outs in line like that.
I would say I like the 3rd best, as the first has warm water going from first gpu to the second, to the cpu then BACK to the gpu's again before its cooled by another radiator. HOWEVER, there are countless articles saying pumps move the water so fast, that the effect of re-warming is minimal. Like maybe 1-3 degrees at MAX. Either way, I like 3rd the best, because i set mine up to get cooling from rads after ever block.
good point, it didnt look natural either. i guess that DEF means 3 then
Having blocks like that in parallel will work. It has been done and it has been discussed many times before. I know this is an old question, but I want future viewers to know.
