Entertainment PC "Click to Help"
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I'm looking to build or buy a Home Entertainment PC to connect in to
my
digital TV - following features must be included:-
1) radio card, and play MP3 files
2) DVD player
3) Ability to record TV to hard disk
4) infrared mouse and keyboard
5) connected to wireless LAN (802.11b) - I work for a wireless LAN
manufacturer so this bit is easy!!
The guys at www.fusionxpc.com look good so far , they have a system
that meet most of my needs...
I am currently in the planning phase - has anybody any ideas on the
spec
of system - i.e. motherboards, processor, graphics card etc
or can you point me in the direction of a web site or 2 with
suggestions.
Including Windows XP (home or pro?) or Win 2000????
Any help appreciated!
Check out "www.fusionxpc.com" media center a tell me what you think?
HTPC help
>my
>2) DVD player
>spec
>suggestions.
>HTPC help
Those systems mostly use custom motherboards
I compiled some htpc links at my website recently while researching this
topic at:
http://timschoenfelder.com/htpc.html
I hope that it helps..
Tim
> my
> 2) DVD player
> spec
> suggestions.
> HTPC help
