So I am not sure how to use the fan hub in my enthoo pro. It says to plug the connector into the CPU_Fan Header, then plug the sata cable into the power supply to use it in the manual, but I have my cooler master hyper 212 evo fan already plugged into the cpu fan header. I would like to know how I could have them both on that header, but I have also heard that you are supposed to plug your CPU fan connector right into the fan hub, and am not sure if this is correct. I would also like to know if I can have different kinds of fans plugged into the hub if I get it to work. Thanks for any help.
