H hiimbatman Reputable Jul 4, 2015 12 0 4,510 Jul 5, 2015 #1 hey guys does anyone know if the enthoo pro case comes with a ssd bracket?
Reyaz123 Admirable May 8, 2015 2,229 0 6,460 Jul 5, 2015 #2 If its this case, yes it has the "removable SSD" brackets. 1 bracket is included. http://www.phanteksusa.com/products/phanteks-enthoo-pro Depends on where you buy it from.Looks for details on the website (if buying online). Call the company and ask them. It is the only way to know 100% if they include it or not Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 Jul 5, 2015 #3 yes it comes with 1 but dont know if its a double or single my enthoo primo has ones that take 2 ssds each Upvote 0 Downvote
H hiimbatman Reputable Jul 4, 2015 12 0 4,510 Jul 5, 2015 #4 yes this is the one but is the 850 evo 250gb good to start with?,i have 2tb hdd http://www.newegg.ca/Product/Product.aspx?Item=N82E16811854003&_ga=1.131637515.542426550.1435431125 Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 Jul 5, 2015 Solution #5 yes the 850 evo 250gb is a great choice price to performance wise Upvote 0 Downvote Solution
Reyaz123 Admirable May 8, 2015 2,229 0 6,460 Jul 5, 2015 #6 Samsung 850 evo is one of the best, if not the best SSD available right now. Highly recommend it. Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 Jul 5, 2015 #7 and same for the enthoo pro in my opinion best case you could have got at the price Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 Jul 5, 2015 #8 and extra ssd brackets if needed are really cheap my primo has more than one mounting point for ssds https://www.overclockers.co.uk/showproduct.php?prodid=CA-011-PT&groupid=2362&catid=2674 Upvote 0 Downvote
