Hey guys,
This is my first overclock and it was fine when running xp i ran Prime 95 for about 4 hours and thourght it would be ok and it never crashed in XP. Then i switched to windows 7 64bit 7100 build, which is fine but when playing games and watching movies etc it sometimes freezes then goes to a blue screen. I thourght it could be a driver issue so i have the latest drivers for my video card, sound and directX.
I was reading in the forums that i have to run prime 95 for at least 12 hours so i set it going and i got an error after 5 hours 25 mins. I have also run memtest+ passing 3 times with each module on its own and then together. So i don't think its memory. Then i was speaking to someone and they said i might have to up the southbridge voltage a little bit as it is related to the video card.
So could someone recommend some settings to use to fix my stabilility issue.
my spec is:
Mobo - Gigabyte EP45-UD3P
CPU - Intel Core 2 Duo E8400 3.0 Ghz (OC 4.0 Ghz)
Mem - OCZ Gold Series DDR2 1066 mhz 4GB
PSU – Coolermaster eXtreme power duo 650watt
GPU – Sapphire HD 4870 1GB
CPU Cooler – Arctic Cooling Freezer Xtreme – with thermaltake back plate kit
HDD - 250GB Seagate 7200.12 SATA 300
HDD 2 – 500GB Seagate 7200.12 SATA 300
DVD RW DL
Monitor - Samsung T240
Case Antec Three Hundred
Thanks Guys
Alex
my spec is:
DVD RW DL
Thanks Guys
Alex
