EPS 24-to- ATX 20 Pin Adapter
d
331
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
i accidentally bought an EPS 24 pin power supply and i have an ASUS A8V
Deluxe, is there anything i can do to convert the 24 pin to 20 pin ? or do
i just need a new power supply ?
A quick search shows adapter cables exist:
http://www.rackmountnet.com/ps/cables/24p-20p.jpg
http://www.vastercable.com/default.php?cPath=10 (bottom of page)
HTH,
Paul
I believe that EPS is going to be the new standard with socket939
motherboards
http://www.msi.com.tw/html/newsrelease/product_news/2004_1021_pciexpress.htm
I count 24 wires on this.
The opposite way around, it should be possible to use atx power supply
on eps motherboard. I know that for a dual socketa board like Iwill
Mpx2 it was possible.
best regards
John
It should just work if there is enough space around the 20-pin connector
on the board (i.e. nothing is blocking the 4 pins from the 24-pin
connector which are not used). It will only fit one way.
Roland
