G
Guest
Guest
Archived from groups: alt.games.everquest (More info?)
Greetings,
I just completed the Enchanted Ring of Torden question (BoT Towers access).
I want to move the ring to my keyring.
I'm pretty unfamiliar with BoT. As a 63 PAL, can use my GVD to invis, run through any of
the wings to get to the CY, run across the CY to any tower port, click in, then get out
again with little risk (assuming my invis holds)? Will I have to use a gate potion to get
out of the tower?
Best regards,
Tim ==
(substitute 'tcsys.com' for 'nospam.co.uk')
_________________
Seeq Endestroi
Paladin of Mithanial Marr, The Rathe
http://www.magelo.com/eq_view_profile.html?num=507035
Grave Wisdom / Grave Intentions - a Rathe Guild
http://www.gravewisdom.com
Greetings,
out of the tower?
Best regards,
Tim ==
_________________
Seeq Endestroi
