• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Erratic usage on RTX 2060 Super? Please help
May 31, 2020
4
I've had this problem ever since I've installed this GPU. I upgraded from a 1060 (3GB) to an RTX 2060 Super. Compared to the other card, the GPU usage as seen in multiple hardware monitoring programs (GPU-Z, MSI Afterburner, HWMonitor, Task Manager) is a lot more erratic and demanding. For example, scrolling left and right on task manager when nothing is open boosts GPU usage from 0%-10% and around there. NVIDIA Shadowplay takes up an erratic 8%-40% when recording, watching a Twitch stream takes up an extra 30%, also fluctuating. My GTX 1060 could handle Shadowplay just fine, at a consistent 10% always. Games and other similar demanding apps seem to run fine, but I feel like they should run a lot better given the power difference between the two cards. Without this underlying issue, it would likely be better.
Video showcasing the erratic usage:
View: https://www.youtube.com/watch?v=Dpj_O-uOvN4
I need some insight whether or not this is really normal.
Things I've tried:
Re-installing Windows
DDU Drivers (I'm on 442.74)
RMA GPU
I'm at a loss for ideas.
Specs if needed:
Ryzen 5 3600x (NO MANUAL OC)
Cooler Master Hyper 212 RGB
MSI RTX 2060 Super VENTUS
MSI B450 Tomahawk
16 GB Corsair Vengeance 3200 MHz (dual channel)
2 TB TOSHIBA 7200 RPM HDD
256 GB Samsung 960 EVO SSD M.2
750w GAMEMAX Gold certified PSU
MSI Gungnir 100 Case (4 case fans pre-installed, 3 manually added)
