Error 1335 ".cab". Please help!
I did a little browsing on the web and this fix seemed to have worked for a few people...
This error is often caused by a firewall or virus software running on your computer. Try the following:
First turn off your firewall or virus software if you have one before downloading.
Open a dos box (Start -> Run -> cmd)
Type in
msiexec /unregister (press enter)
msiexec /regserver (press enter)
Now try installing the program (without firewall or virus programs turned on or running)
Any luck?
Cassandra
Microsoft Windows Outreach
thanks, Tried it mate but still wont work. 🙁
all programs with .cab file. almost tried everything. from installing 'installshield 2010', winzip, winrar, but still no luck.
